Re: Early 50's Evinrude? should I buy it?
Spent a long day in the ICW south of Savannah, GA because of the two-line fuel tank with a motor just like the one you are looking at. If you do buy it, please convert it to a single-line tank for safety reasons! I had a bilge full of gas before I ever knew I had a problem. When the fuel side of the two-line hose leaks, the motor continues to run on the fuel remaining in the carb which also continues to pressurize the tank and pump gas from the leak. Fortunately, we did not have a fire. Good luck and be safe.
