Starting to winterize da boat.
Mover her to her "sleeping spot" in the yard.
Figured I check my "no oil" alarm. (I knew it worked I get the quick "beep" with the key, but what the heck, lets play).......
Popped the cover off, checked the alarm, (yep it beeps when grounded) and was playing with the motor.
I turned the electric primer lever (cuz it's a lever and it's RED, just begging to be played with!), it came out in my hands!!!!!!!!!!!
(the valve is closed) and can be open/closed by putting the lever back in and pressing on it and turning.
Open, fuel comes out of the red shaft of the lever, but, closed nice and dry.
Should I replace this lever or just leave it alone? (I was thinking maybe try to epoxy it back on).
(I noticed it was hard to start last few weeks, had to open the throttle, (I didn't at the start of the season) didn't seem like when I pushed the key in it was working, (after it fired and was sputtering I figured it'd rev up or?? but seemed like nothing), but would fire none the less).
I chaulked it up to tinkering with the idle mixture and I believe have it a bit lean, but maybe the solniod is bad or the broken lever had something to do with it?
I dunno HOW or WHEN the lever got broken, but I noticed it now.
I gonna test it tonight, IF I turn the key on, press the key in, I should feel? hear? the click?
Should I add that to my "to do" list?
Anyone ever had one apart?
Joe
For a boat that need "nothing" the list is getting longer n longer!!
Joe
