electric shift help
67jupiter
my first 16 foot boat :joyous:
but it came with a birds nest of wire
if the pic works and you can help or ster me
to help. thanks for any help
Mohawkmtrs
Go to maxrules dot com, click on Technical Specifications, click on Common Wiring Diagrams, click on your engine.
Ayuh,.... Welcome Aboard,...... What exactly is yer motor,..??
67jupiter
72 Johnson 65 hp 50th ed. Es
from what a read here I want the blue and green wires to shift.
but mine is wired black and purple.....
67jupiter
Not sure but I think it is wired to always be in forward...
purple choke switch and switch on the black to kill motor....
also my ignition has a red wire so the harness might be for another year
not sure as this makes my brain hurt
When the motor is NOT RUNNING it will be in forward.------Shifting is done by solenoids that direct oil pressure.-----12 volts to the green wire puts it in nuetral after one turn of the flywheel.----12 volts to green and blue together puts it in reverse after 2 turns of the flywheel.-----You can operate the control lever all day long and it does not shift if motor is not turning !!!
Faztbullet
The 3 wires near plug you labeled not used are the shift wires...those should be connected to a selector switch in control box
67jupiter
Ok I get how it is supposed to be.
no wires are hooked to control box. So always in forward.
I will try the three wires and hope the relay works.
what would the switches be for? Red ign to black and purple to purple ?
F_R
Where did you get that dumb diagram? I quit looking at it when I saw 1960 75hp. NO Way. Anyhow, try this. And note that it takes the yellow plug cable.
I thinks you have the wrong control box.----Is there an ignition and choke switch on the control box , yes or no ?--Is there a big YELLOW plug where it plugs into the motor wiring harness, yes or no.------Yellow plug was only used for the 72 model year for the 3 cylinder motors !!!
jimmbo
That looks like a control box for 1962 - 1968 electric shifts. Hydro-Electric 55hp not included. As Racer said, the correct control box would have the ignition and choke switches integral to the control box
Click image for larger version  Name:	zxz.jpg Views:	1 Size:	140.3 KB ID:	10723415
Funny how there is no response from some folks when you point out the facts.
