egldvrbags
Thread starter- Joined
- Sep 8, 2007
- 105
1995 Bayliner 2050 LS
4.3 LX SN 0F436164, Merc Alpha 1, Thunderbolt IV ignition
Wisconsin fresh water boating
Engine completely rebuilt by Merc shop this past winter, 20hrs on it since then. Engine runs and purrs like new, except....
On 3 occasions in past month (1 at 1500 rpm, 1 at 3000 rpm, and 1 at 3500 rpm), all cruising (ie, steady throttle), I've lost all electrical power and obviously the engine dies. The one at 3000 rpm "coughed" from what sounded like the carb when it happened, other 2 no strange engine noise.
After switching the key off and on once or twice, the power comes back and it restarts and runs normally.
When this happens, I have no power at all - blower, radio, etc that usually work even w/ ignition switch off.
I've checked the kill switch, all leads from the battery, leads on all the gages, and all other wires I can see. Nothing appears loose.
I noticed at the beginning of the season (and even last year before the rebuild) that occasionally the tach would jump up about 1000 rpm for a few seconds with the engine at constant throttle. The engine didn't change speed. I pulled the leads on the tach, cleaned, and reinstalled and it hasn't happened since about June, so I don't know if this is related.
Any ideas?? Bad ignition switch??
Thanks,
Dave
Thanks,
Dave
