txcopfromcali
- Joined
- Mar 11, 2008
- 30
I just had a new battery installed (less then a month ago) with a higher cranking output which helped resolve my previous starting problems. Now, I recently attempted to install an electric fuel gauge and sending unit, and in doing so, I unplugged an accessory outlet which I did not use, with the intention of using those leads in the installation of the fuel gauge. Since I have done that, I lost mostly all the power to any items, however the depth finder is making a ringing sound, indicating it is at least receiving power. No other item is receiving power, tilt/trim wont activate, ignition wont crank, and electric fuel pump, bilge pump, nothing else has power.
Where do I start? May I need a new regulator/rectifier?
Thanks
Thanks
