alumi numb
- Joined
- Nov 12, 2008
- 299
Re: Engine aligning
will do in the a.m. navis.
most of the floatation was fine so i reused it.
anything with deterioration didn't go back in.
for the rest and extra that i'm going to add in the sides i'm using pool noodle.
seems to work real well and not messy.
they seem to handle 50lb's fine and the boat is supposed to weigh in around 1900 lb's so i see enough voids to handle around 45 of them.
along with the original i should be fine.
i built a new front base "wood as was" for the motor mount so will need to realign.
still have a long way to go but will have finished by spring.
going to have made and plan on using 1045 for the tool, then i know it won't flex.
thanks.
thanks.
