engine and out drive installation...
Rick Stephens
Not a clue. I don't recall any washers that were imprinted with a bolt head. Might just have been one of the transom studs overtightened?
rickasbury
I think the imprint is not made that way, it is aluminum I think....It will not fit on the studs but maybe because it was bent up...if so, I only have two....will check back on the parts list. Thanks,
Ayuh,..... The rear motor mounts use an aluminum washer on top of the spacer, under the bolt head,.....
That one was severely over-torqued,.....
