Rick Stephens Admiral Joined Aug 13, 2013 Messages 6,118 Aug 30, 2018 #22 Not a clue. I don't recall any washers that were imprinted with a bolt head. Might just have been one of the transom studs overtightened?
rickasbury Master Chief Petty Officer Joined Jul 13, 2011 Messages 832 Aug 30, 2018 #23 I think the imprint is not made that way, it is aluminum I think....It will not fit on the studs but maybe because it was bent up...if so, I only have two....will check back on the parts list. Thanks,
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,463 Aug 30, 2018 #24 Ayuh,..... The rear motor mounts use an aluminum washer on top of the spacer, under the bolt head,..... That one was severely over-torqued,.....
