Donald0039
- Joined
- Jun 11, 2022
- 482
Had not been to be that in awhile and so I connected the muffs and turned on the water and as normal water shots out from the muff rubber part touching the outdrive. Then started the engine. Normally with the engine running only a little water comes out from around the muff rubber part. This time did not seem a difference engine running or not.
Little or no water coming out of where I expect to see water with exhaust.
I/O is a VP DPA- OXI.
Engine is a 2012 V8 5.7L with closed cooling.
I guess I will come back and pull the raw water impeller.
Maybe connect garden hose direct to engine port.
Will the raw water impeller vanes flip when engine is started if I somehow got them pointing the wrong direction last time I installed new raw water pump?
