Re: Engine Gear ratio
On a 2.25:1 ratio it means the flywheel will turn 2 1/4 times to make the propshaft turn once.
Here's what we do to fo figure it out easily. If the lower unit is still on the motor, pull the plugs to make it easy. Mark the flywheel and propshaft. The marks don't have to line up with anything in particular, whatever's easy for you for counting.
Have someone watch the propshaft while you turn the flywheel. Look for the propshaft to turn 10 times. With a 2.25:1 ratio the flywheel will turn 22 1/2 (22.5) times. You could turn the flywheel just enough to make the propshaft turn one complete revolution. The flywheel should turn 2 and 1/4 times. We like the 10x deal just because it's more accurate. But in your case the flywheel will turn over more than twice (2.25 times) or not quite 2 (1.87 times) if it's a true V6 case.
If you use the 10x deal and it's a true V6 case the flywheel will rotate 18.6 times to turn the propshaft 10.
