I have a 95 chris craft 30 crown - twin ford omc cobras
When I turn the ignition switch i get gauges - then when I turn it to engage starter - the starter will engage and will not stop even when key is turned back to off. I have to turn the battery off to stop it from cranking.
I replaced the ignition switch and it does the same thing.
The port motor is fine and does not have this problem.
