Engine stall
cheetah86
1986 Mercruiser 140 HP 3.0 I had changed head gasket and starter. Idles good. When out of water, doesn't seem to be a problem, good rpm's. When in water it will cruise for about 5 min at a low speed. When I give it gas it starts to go fine but after a few minutes dies out. then trouble restarting. Bad Gas? Also noticed I had lost fuel cap some time back. What do you all think? Thanks.
180shabah
Re: Engine stall
Could be bad gas, clogged filters, weak pump, A/S valve, tank vent, are any fuel lines kinked/pinched???
Check out the adults only section for reason can't reach WOT
cheetah86
Re: Engine stall
I had changed filters. Don't know what A/S valve is or tank vent. No kinked lines. Added sea foam and some booster to gas but no change.
fat fanny
Re: Engine stall
The anti siphon vavle is located right off the elbow of the pick up tube pull the tube out and clean it along with the vent which maybe part of your missing fuel cap.
fishinpa
Re: Engine stall
Hes talking about the anti - syphon valve in the fuel tank .
sea foam and booster wont help if you have bad old gas or water accumulated in tank.
fish
jimmyebay
Re: Engine stall
i would pull sender from tank and pull all fuel out and start with fresh gas. kinda weird it idles fine, but i have seen bad gas do this...
cheetah86
Re: Engine stall
drain gas tank? was reading other posts about coil problems? points? Are these possible issues? THANKS. I'm in Northern Va. sorry bout that.
cheetah86
Re: Engine stall
Yea, if I "REV IT UP" when in neutral the rpm's go all the way up to like 7000. But it kinda starts poppin a lil'. Only acts up when in water and in gear to try to take off.
180shabah
Re: Engine stall
You are freakin' kidding right????
7K what about that seems like a good idea to even try????
That engine will hit it's redline on 2 cylinders with no load, so what you are doing is diagnosticaly irrelevent and just plain stupid. Do you have any idea what happens when pistons and valves collide? It ain't cheap.
How many items on the can't reach WOT list have you checked off?
