Engine wiring harness cleaning and repair
TrickyRicky
1978 Johnson 55hp. Appear to have an aftermarket wiring harness that looks to be in good shape except for the pins on the main connector / plug on the engine side. I was able to "disassemble" the plug remove the female cap and adhesive holding the pins in, remove them and clean all the pins.
Now I want to glue the pins back to the rubber base. Anybody done this before? I don't think silicone will hold pins good. I have been trying to think of a good glue / sealer. I wanted to try some 3M stuff I had but it doesn't seem to cure when it is real thick. Ideas?
