Epoxy Resin adhering ot old gel coat
83mulligan
My boat has what appears to be gelcoat brushed into the bilge and sole area of the boat. Does this have to be ground off to get a good bond between the new fiberglass with epoxy or will it adhere ok? How do I know if it is gelcoat or paint?
ondarvr
Re: Epoxy Resin adhering ot old gel coat
Polyester resin and gel coat are basically the same thing and epoxy will bond to both very well.
Paint is normally a thin layer when compared to gel coat and if you sand on it it acts much different.
83mulligan
this stuff is really tough to grind off. I'll try and get a picture up later.
Ayuh,... If there's Any question about it,... Grind it out....
A lay-up is only as Strong as it's weakest link.....
