Ever heard of filing a bare block with gas to check for crack?
snake91876
Local machine shop said they fill the bare block water system with gas to check for leaks, they said gas will immediately seep through a crack and show you where the leak is.
bjcsc
Re: Ever heard of filing a bare block with gas to check for crack?
I am assuming you mean gas as in propane, etc. that they can detect with some kind of instrument?
Coors
tell them to use rubbing alcohol- It won't blow; but will seep fast.
snake91876
they set block upright filled water passages all the way to deck with gasoline and it came out nowhere, they are telling me the block is not cracked, it has no visible cracks
HT32BSX115
A very reliable way is to check it before you take it apart using an air compressor.
You pump it up to 15-20 psi and use a squirt bottle with soapy water to spray it with.
bubbles indicate a leak.
Cheers,
Rick
Coors
HT is correct.
Put pressure in it.
Boomyal
HT is correct.
Put pressure in it.
Methinks that would be difficult on a bare block sitting on the bench.:eek:
Coors
Before, Boom.
DaveM
This is brilliant! Talk about a great 4th of July pyrotechnic!! But serially, I'm sure this is perfectly safe. Just let me know where I can watch (from a distance).
