Evinrucde 89' 88 special, loses power after 2,000rpm
KCKracker
its my buddies. it runs and idles great, gets up and scoots but at 2,000 rpms it tops out, thats it :confused: it wont go past 2000rpms
Bosunsmate
Re: Evinrucde 89' 88 special, loses power after 2,000rpm
Is the timing plate and carb opening properly- in synch- right to the end of throttle range?
KCKracker
how do i check that?
Bosunsmate
Well you really need a manual. But does the throttle plate look horizontal with the throttle in full position?
Is the timing base rotated to full advance when the throttle is in full position or is it stuck
Honorary Supreme Mariner
Is the tachometer set to read correctly ????
