Hello!<br /><br />Put my boat in the sea today after winter. Everything seemed to work fine, so I took her out for a ride. The engine acted normally. So, I started by going at slow speed for about 10-15 minutes, and then I run her a bit harder, about 1/2-3/4 throttle. Everything worked fine, but after say 5-10 minutes she suddenly died. <br /><br />There was no fuel-pressure. I manually pumped the fuelbulb and restarted again. But as soon as dropped the manual start-throttle to bottom, she died almost immediately. I managed to ge her going by beeing fast and putting forward gear in before she died. With just a little throttle she worked just fine. A went home again and she behaved as usual. But still wouldn't idle... <br /><br />Any ideas? I changed the water-separator just before I put her in the sea. I have also had the tank half-filled, which might no have been a good idea. Could it just be that the idling throttle is set to low?<br /><br />thankfull for any tips..
