wetwaterdog
- Joined
- Apr 2, 2012
- 8
Hopefully just a quick question. I had to rebuild the carb, re-cut the spark plug wires to the coils as they were corroded, and put in new points and condensers. I want to make sure I set the points right. I placed a red mark in the picture where the points arm touches the cam.
I see the "top" on the cam marked. Do I set the points open at anywhere within that "top" mark, or do I start as it turns CW to just the beginning of the "Top".
What about throttle position on the arm...leave that to "Stop" (off).
Do I care where the timing marks are on the lower fixed piece?
Can I just put the shaft nut on and turn the cam 180 degrees to set the other points.
I have done some reading on the site and from what it looks like, it is just rotate the shaft to the "top" position, set one set of points, then rotate the shaft via either the nut or putting the flywheel back on, then set the other.
Thanks,
Thanks,
