mrfixitman40
Thread starter- Joined
- Aug 13, 2007
- 286
Re: evinrude charging system modification
ok just to update the charging situation i believe my amp gauge is screwed up i checked charging volts while on the lake running it is 15.8 volts but the gauge shows nothing but it will show discharge if i run the 12 volt inflator with the tube one other thing is that i do charge the battery on a trickle charger the night before so maybe i was just being a little to cautious and worried a little to much all seems fine if i see any other problems i will be sure to advice here after i check the voltage again thank you all
