Gibsonman2005
- Joined
- Aug 23, 2014
- 75
So I finally looked at the coils through the window oldboat1 talked about and they look brand friggn new in there. ??? Not only that but the fasteners and hardware look new too. ??? I kinda tried to check the gaps and reaching through the window I gapped at .020 or maybe a bit more on the smallest gap of all points. I also removed the generator belt. I'm really not looking forward to removing the flywheel so I'm procrastinating in a roundabout way I suppose. Anyway, after new plugs and solenoid and ignition switch (B terminal broke off of old one not even orig) the motor cranks maybe once or thrice and nothing. Gonna do comp test and spark test tonight. After that I guess it's carb time if comp and spark are good. Any other suggestions as to why it cranks and cranks? Grounds are good. Connections clean.
