evinrude prop size?
mrc283
aight i kinda lost my prop(long story) anyways, i need to know what size to get. its a 1977 85hp evinrude, thanks
Tacklewasher
Re: evinrude prop size?
Size is 13 1/4, 13 spline. What pitch is a whole different question.
What did you have before and how did it perform? What was the max speed and RPM?
walleyehed
If it was an OEM OMC, yes, the 13 spline hub, but diameter can range from 12-3/4 to 14" on this engine.
13.25 diam would be a 17P, 13 diam is 19P and 13-3/4 is a 15P
The 14" diam can be 13-19P.
What boat do you have?
Randybeall
You have a problem if that is all the information you have. The only way reasonable from there is to find a prop supplier who will allow you to try multiple props until you find the correct match. I would take a WAG at a 13 x19 based on the power and boat description as a starting point. You will need to run Wide Open Throttle tests to find out if the engine reaches rated rpm with each prop you try.
