If it was an OEM OMC, yes, the 13 spline hub, but diameter can range from 12-3/4 to 14" on this engine.
13.25 diam would be a 17P, 13 diam is 19P and 13-3/4 is a 15P
The 14" diam can be 13-19P.
What boat do you have?
You have a problem if that is all the information you have. The only way reasonable from there is to find a prop supplier who will allow you to try multiple props until you find the correct match. I would take a WAG at a 13 x19 based on the power and boat description as a starting point. You will need to run Wide Open Throttle tests to find out if the engine reaches rated rpm with each prop you try.
