duckland23
- Joined
- Apr 23, 2012
- 175
Hi guys Im wanting to get all the specks for the touqe and any other specks I may need to rebuild my engine . I would also need the bore size , over size bore size too . piston ring end clearnce , rod touqe for bolts , anny outer cover touqe if needed . Please list everthing I would need it you can . I sorry to report that it did not change my compression reading from dry 30 psi . My wet was 55 in the two cylinders . Thats alot of work to do to the engine , But the good thing is that when Im done its going to be like new again . I'll make sure she runs on a heavy two cycle oil mix like 24:1 or 16:1 what ever that is in ounces of oil . I flowed the standard oil mix for two gallons of gas , But I only used less then 1 gallon from the time i owned her . Its only a month or so . I got her from craigslist .
