greasemonkeyjmj
Thread starter- Joined
- Jul 7, 2008
- 264
hello my latest project is a 72 or 73 evinrude 25 horse with points type ignition. i pulled the flywheel off to take a look at the coils and points and such, and discovered that eveything under the flywheel was covered with what smells like premixed fuel. my first thought was that the upper crank seal is bad, but the engine is able to idle down and run good. if it was a bad seal, wouldnt it have problems at low idle due to sucking air in ? also what effects will the wetness have on the ignition ? I actually tore into the ignition due to the fact that i am have a problem while accelerating under a load with the engine dropping in and out on one cylinder.
thanks
thanks
