Excessive compression..
frustratedboater
Re: Excessive compression..
***Been thinking as I said that I checked over the studs, but wanted to look at them again. I got down low and looked across the tops of the rocker studs and I did see that the #4 cyl studs both are raised up which would explain the 'looseness' I'm experiencing. They look as if they pulled out a 1/8". This is most certian the issue! It explains the noise, clattering, and the pop noise under the intake manifold. Is this something that I can just tap back down, or will I have to take the heads to a machine shop?
dontask
Before putting a wrench on it, do a compression leak down test. It may well pinpoint the problem for you.
I agree on this method of starting a base line of the condition of engine. All of the other parts and labor are just a waste if the engine has compression issues.
JustJason
unfortunately it's got to go to a machine shop.
