Re: Fails to choke at start
I agree completely!, but if the engine was running good before why mess with the distributor, and take on a whole new can of worms? I think you should finish checking items that you have started before taking on anything new. Best bet is just put a timing light on it while cranking, then if need be just loosen your distributor a bit, and move it as needed to match up your timing marks, then tighten it up, and move on to previous issues.
Thanks, good advice and this is how I started today. I had plenty of things to do and try before reversing the distributor (which I ended up doing).
Let me start by saying it's running again.
What did I do today;
1. re-terminated the resistance wire
2. made up a remote starter switch (working alone again)
3. confirmed the timing (BTDC 10+, as prescribed in the specs)
4. emptied the in-line fuel bowl and fuel water separator into a clear container (a bit orange, some minor sediment, and a bit of water or something settled out)
5. blew out the fuel line to the tank. (didn't seem plugged at all, easily blowing bubbles)
6. plugged the fuel line and grabbed a fresh 2 gallon fuel can and used a small hand pump to prime the line, in-line bowl, and fuel water separator. ( this exposed a small leak on the inbound side of the fuel pump (tightened this up).
7. Started as before, maybe even ran a few seconds longer, but still quit (multiple attempts.)
8. Moved on to rotate the distributor 180 degrees. It took a while but I reestablished the timing. Surprisingly the rotor still doesn't point where I expected at TDC. (looking at the engine from the front it moved from 8 p.m. to 4.p.m.)
9. Started as before (like in step 7), again, maybe a little better, but no idle.
10. Stumped and out of ideas I returned to everything you all said (Ignition and Fuel)
a. Ignition seems fine (everything checked out)
b. Fresh fuel, alternate source
c. Timing set to specs.
d. Compression ok.
e. Carburetor (has to be)
I went back to the adjustment instructions (dry & wet). I haven't done the wet adjustments because it wasn't running. So, I thought how about doing the wet adjustments without it running.
They talk about emptying the carburetor bowl, running the engine, removing the sight screw and ensuring the fuel level remains just below the thread for the sight screw while running. I checked it after attempting to start and gas dribbled out enough to wet the rag I held under the bowl. So, I adjust the flow level an 1/8 of in inch.
It started, I was able to advance the throttle and keep it running, back to idle. Up to temp, shut it off, started again at an idle.
I seems it was flooding.
It ran a bit rough at 2200 rpm, vibration - pretty noticeable, and some vibration at an idle of 900-1000 rpm. This is new, didn't vibrate a couple months ago during it's brief running.
I loosened the distributor hold down bolt and it immediately sounded better. I turned it left and right until it ran smoothly, but every time I tried to tighten the bolt down it it ran rough/vibrated again.
I was out of time I had to quit for the day.
Tremendous progress. Thank all of you for all your patience and experience.
What's left?
1. I have to resolve the vibration problem. (Timing, loose timing chain, ...?)
2. Empty the main fuel tank. It can't be good. Maybe it would run ok on it, but I'm really not happy with the color or the fuel after comparing to the fresh 2 gallon tank.
But it's running again (BIG SMILE)!!!
