Fancywork on boats/wheels
How many of you have some fancy ropework aboard your craft? Perhaps a flemished or coxcombed wheel or rail or a bellrope, or.....<br /><br />Post a pic for us to see!
KilroyJC
Re: Fancywork on boats/wheels
Nothing on my boat yet - I have to fix the transom first. When I get home Sunday night I'll put up some pics of a fishing rod I did some fancy work on...<br /><br />On my first car I covered the steering wheel with hitching because it got too cold in the winter, & I didn't like any of the cheesy wheel covers that were available at the time. I should've removed the wheel before I junked the car. Oh, well...
KilroyJC: Yeah, "should'a, would'a, could'a.." Hindsight is a bummer, innit? (Love the sig., by the way!) Over the years I've done fancies on things that then "went away" and could kick myself now. BMC I worked for had Macnamara's Lace in rear window of his junker and when it finally died, he just surveyed it and left all the fancywork in place without thinking... he regretted it later, but by then it WAS later, eigh?<br /><br />HollaGeo: Glad I'm not "foolin'" you. Now, if I knew what you were talking about...
Ah! Now THAT'S some good work! Nicely done needle hitching, but I'd love some Hi-res pics (esp. #3 & #4) if you wouldn't mind (and if you're not on dial-up!) to me at admin@frayedknotarts.com.<br /><br />Again, very nice work. What did you use for line?
KilroyJC
I gotta be honest - there's no needle hitching here...<br /><br />#3: First, I wrapped the bare aluminum buttstock with friction tape. Then I laid strands of tarred netline (I think size #36 or so) parallel to each other on the buttstock, and seized them middled with a constrictor knot. I then angled them parallel at about 45 degrees, and when I got to the reel seat, seized with another constrictor. I did the same thing towards the bottom end, and then applied turksheads over the seizings. On the bottom turkshead I smeared a little Goop adhesive to seal & protect the lower edges.<br /><br />#4: Again I wrapped with friction tape. Started off french hitching up with #20 tarred netline, then decided I didn't like it, so I simply served over it, & applied turksheads over the seizings. Then I took strands of #60 tarred netline, & Laid them parallel with #60 spacers (2-3inch pieces), Seized it, then pulled the spacers. Then I wrapped that with friction tape & did it again, because I wanted a fat grip, but also wanted to go up onto the narrower fiberglass as well. Then I just walled up from there. Then I got to the end of the aluminum, I finished off with a Matthew Walker knot, and went back to walling up with the next set of strands, also finishing with a MW knot. This can best be seen in pic#1.<br /><br />You can click on the pictures for a full size view, too.<br /><br />All this does add more weight than is necessary to the rod, but I'm not about to do it over! :D <br /><br />I'll take some pics later in the day & send them out. <br /><br />Glad you like it!
Will be up in Mystic area this weekend.... any suggestions for things to see other than the Seaport Museum and ship areas?
Here's a goodie.... JOHNR of Kitenui (Auckland, NZ) sent a pic of a "sea mat" or "carrick mat" being used as chafing gear under the pilot of his new tiller. There's an actual reason this stuff was all devised! <br /><br />
Not strictly a piece of fancywork ON a boat but one which definitely is USEFUL aboard!<br /><br />
Anyone else got anything nice?<br /><br />Can't believe there aren't any wheel covers out there!<br /><br />Hippo Hollydays to all!<br /><br /><br />Vince
Sorry, no adverts allowed here. By SBN
KilroyJC
I have to redo my transom before I start playing with a fid anywhere near my boat...
tashasdaddy
i want mine plain and simple, if you like it, enjoy it.
