fiberglassing holes
friderday
my son & I(mom) are currently rebuilding 14' Ashcraft from stringers up. we have done some hull repair, including glassing some cracks & holes in hull & keel with great ease.Stringers will be next. My question concerns another old boat of ours (15' Answer). It has a couple structural issues I am repairing since fixing other boat has given me confidence. Where the gunnel meets inside(side of boat) & top of transom near pole holder(corner), there is gelcoat crack & fiberglass failure. I can cut this out easily, but how to rebuild it is confusing me, since there is no other side access like on the bottom of a boat. In other words, a hole in hull I can patch by putting a backing against outer hull & layering until I get desired thickness. Then remove backing & gelcoat from outside. This one I can only access from out side. The area I would need to cut out would be about 6" along top of gunnel, BUT also down inside wall about 4". Any tricks to this project? I was thinking some material(thin) that has flexibility that I could stuff in held by a knotted string that I could hold as a form of the original contour to glass over to start lay. I am perplexed on this one, but sure there is an easy solution I'm not figuring out. Sorry-no pictures available.
Re: fiberglassing holes
Ayuh,.... Welcome Aboard,... Got a Picture or 2,..?? What's behind the area,..??
My 1st thought is,.... Cardboard.... tape it up, 'n build out...
friderday
Thanks for quick reply. My camera stolen recently. Try to borrow one. Yeah, thats all I could think of too. We'll see if anybody has any better ideas. Think I can make that work. Nice to be on here finally. Friscoboater Jay has been helping with some advice on my son's rebuild. He is amazingly talented & very nice to offer so much time/advice. I have messaged him on facebook. Will see what he comes up with. Thanks again & any other suggestions still welcomed.
Afzape
You could try to find a really thin cutting board. Scuff it up real good, put a hole in it for a knotted string, fold it and shove it in the hole and then pull the string tight and lay the glass.
