Ficht leaks fuel.
jerryjerry05
Johnson 150 Ficht.
Not sure of the year???
# on the silver plug 4886732
As you(me) squeeze the bulb fuel squirts out the top cyl or hole for the top cyl. see pic by the #1 What's behind there that lets fuel out?
THANKS
When you run it runs but not as good as the second motor.
oldboat1
Not a clue, Jerry -- but #9 and #35 appear to be nozzles -- maybe part of the primer system(?) Could be normal.
oldboat1
Ball obviously wouldn't get hard if fuel is blowing out as fast as you pump it.
jerryjerry05
It's a 2000 Evinrude 150
The vapor separator isn't like the rest of the world.
Just wondering if the injector could be leaking past??
jerryjerry05
Took the vapor separator apart and the needle is defective.
Has the soft rubber tip and it's screwed.
The bad: they don't sell separate parts for this thing only whole units.
The start at 350$ used if you have one or the needle/seat and cap laying around send me a PM.
