Finished motor rebuild. Pics
Kevin70
Finished putting my motor back together this past weekend. Now I have to start on the outdrive.
Before
After
You can see bigger pictures if you click on the link below.
tashasdaddy
Re: Finish motor rebuild. Pics
nice job
KaGee
Cool!
Mark42
Wow, looks good. I went through your project, that is going to be really nice when you're done.
Kevin70
Re: Finished motor rebuild. Pics
I can only hope it comes out as nice as yours, Mark. Thanks.
Boomyal
Nice job Kevin. How'd you prep the block before you painted it?
Kevin70
I just sanded, sanded, and then sanded some more. Then cleaned it with acetone for about two hours and put about five coats of "Ford red" block paint on it. All of the black is a combination of block paint (exaust manafold) and epoxy enamel.
Bob_VT
Make sure you prime the oil through the motor before you start it. Looks great!
Kevin70
How do you do that, Bob?
Mark42
Usually it's done by turning the oil pump manually with the distributor removed. But on that Volvo motor, I don't know if the oil pump is driven off the cam/distributor drive. I think that motor is OHC.
Check a service manual to be sure how to do it.
Bob_VT
Leave the fuel disconnected, remove the plugs and crank it for a minute to get the oil through the system. Most motors as Mark had mentioned you can remove the distributer and use a spare shaft (if you have one) to turn the oil pump.
Additionally, people used to put vasaline in the oil pump before assembly completion.
You just want to make sure everything is properly coated for the first start.
Kevin70
Thanks a million. You guy are awesome.......and cheapd:)
NBE
That engine came out great. You should be really proud of it. If it runs as good as it looks you'll have a heck of an engine.
Kevin70
We sure have our fingers crossed, nefferso. Thanks
Kevin70
I have to do the big "compression check" this weekend. I turns over very nicely by hand and gets pretty hard to turn on all of the compression strokes, so I'm hoping for the best....wish me luck.
