Chris51280
Ensign
- Joined
- Jan 24, 2018
- 933
So here is my thought. Steve put it back the way it was.
Is it how it would be build today? Probably not.
Is the bottom bolt on a good solution? Probably not.
Will it break apart because it is only supported at the ends? Probably not.
It worked before so I think it will work again. If you can change it with the neoprene strips then please do so. The tank has beveled sides that help with rigidity of the bottom. I see that you don't have much room on top of the tank to mount to the side of the stringers.
Like I said, when in doubt, put it back as it was. can't be wrong since it worked before and was approved back then by the coast guard. Make sure the flange will stay dry and seal the screw holes with PL or 4200 or 5200 and don't drill through.
That's why we come here and question everything and get 10 different opinions. Its up to common sense and the builder to decide what to do. There are 10 correct answers and then there are 10 wrong answers. And even that is in the eye of the beholder.
