Re: fitting short shaft as back up motor
Sure, you can install a trolling motor bracket. These allow you to lift and lower the aux. motor. I do how ever advise caution when using a short shaft motor. Because when in use the motor will set low behind the tramsom and is not proctected by the motor well, it has a tendency to get pooped in rough water. This is where a wave bounces off the stern and drouns the aux. motor.
