*** FIXED ***boat wont start since putting in new battery, having brain fart help pls
Don S
Re: boat wont start since putting in new battery, having brain fart help pls
How are you testing?
First, hook your black meter test lead to a good clean ground. When you check the terminal with the red test lead from the starter, you should show 12+ volts. Then move the red test lead to the other terminal, it should show the same voltage.
If it shows nothing, you have a bad breaker.
macr6
That is how I am testing it.
Tested the pos terminal to the solenoid = 12.75v
Tested the wire after the fuse on the solenoid = 12.75v
Tested the wire coming from the starter to the breaker = 12.75v
Tested the other terminal on the breaker = 0v
I am testing just as you said to do. I am using the neg terminal of the battery.
Don S
Then you need a new breaker.
Hansolo99
Sounds like the breaker.
macr6
Don, I swear as God is my witness, if you ever make it to the norther virginia or Lake Anna area I will buy(spelled buy wrong and had to fix since my jack***** sister-in-law pointed itout) you a drink.
One 58$ part later and everything works.
Thanks for helping me systematically troubleshoot this problem. I was all over the board.
Hansolo99
Don, I swear as God is my witness, if you ever make it to the norther virginia or Lake Anna area I will by you a drink.
Another satisfied customer. Good job Don!!! Thanks for the update on this..
Don S
Glad you was able to find one on Memorial day. You were lucky.
Bet you keep that meter on the boat from now on, won't you :p ;)
macr6
Well now I have two. Since we were down at the lake my wife had to drive about 40min one-way to wal-mart to pick one up. So now I have a spare for the boat. Going to put a small socket set and screw driver set in the back of the truck as well.
Again thanks for the help.
