Britcheflee
Thread starter- Joined
- Oct 4, 2010
- 79
So, just got the flywheel off my 7.5 fleetwin - I purchased this from Kragen for $16.99:
http://www.oreillyauto.com/site/c/s...9/C2371.oap?keyword=harmonic+balancer+pullers
It does NOT have the correct size bolts for this flywheel so went to NAPA and got 3 hardened bolts and washer for $3.60
Set it up and started cranking down on it sprayed it with pb blaster the day before, gave it some heat and continued tapping (not whacking at it) then another turn and tapping, bit of heat more spray - took about 30 mins before she gave and it is correct it goes with a small bang.
So, have the old cracked coil in hand - NAPA has the part which is more expensive than this site but with shipping for me probably a wash. Will replace tomorrow.
Question: Does the darn thing come off easier next time? I am only going to replace the bad coil at the moment as the other looks just fine (a dark blue color) so if it fails I can probably replace fairly quickly now I have tools etc.
Lee
Lee
