I have a 1976 Glastron T-156 and I'm replacing the floor. I bought a toe-kick saw to cut the flooring along the hull. It worked great but with my fogged up goggles on rendering me basically blind, I made a very professional looking saw cut about 15" long near the back of the boat where there is a rise in the hull. To repair my screwup I'm considering putting 2-3 layers of fiberglass cloth with 2-3 layers of epoxy resin on the inside. On the outside I plan to put one layer of cloth with a coat or two of epoxy resin. My first question is this: would this be a satisfactory way to make the repair? Or is there a better way to do it. I especially like the idea of putting a layer of cloth on the outside as it would be a constant reminder for me to never again attempt to replace a boat floor. For the flooring I'm using 3/4", 11 layer hardwood plywood which has a very smooth surface. I plan to put two coats of epoxy resin on the bottom side and along the edges and one layer of cloth with two layers of epoxy resin on the top side. My second question is: should I rough up the surface of the plywood a little with some heavy grit sandpaper or leave it as is. I'm trying to complete this job without totally destroying the boat and any advice will be greatly appreciated.
