Re: Floor replacement question
Well, I sanded the transom outer skin today. I used a tyvek suit with a respirator and glasses-type goggles. After sanding a little, I noticed that some dust was still getting in my eyes, so I added a face shield on top of everything and that seemed to work well. The respirator lower strap kept loosening and I had to keep tightening it. One trick I use to see if the respirator is leaking is to momentarily cover the respirator modules with my hands and inhale, if they are sealing properly it will be difficult to inhale and the mask will attempt to collapse inward. I may still look into a full-face respirator, as it would be a lot more convenient. The tyvek suit kept the itching away, except for one spot. The sleeves kept pulling up a little away from the gloves, which I ignored and now am itching in the wrist area. Here is a picture of me with the whole works:
Here is a picture of the transom after sanding:
I sanded the transom and a band about 5" wide around the perimeter of the transom on the hull. I also sanded into the recessed areas of the transom where the foam was dug out in the upper right and left areas since the core will be tabbed to this area also. You can see the recessed area here:
The next picture shows how Larson added about 3/4" of foam to the port and starboard hulls and then glassed over the foam:
This foam layer extends to about 2 feet forward of the transom and then tapers dpown to nothing but the actual hull. The transom was tabbed to the glass on top of the foam. Not sure why Larson did this. I have removed the foam near the transom and will tab the new core directly to the hull. Then I will match the new tabbing to the thicker foamed area with some glass so it looks better than just ending the foam suddenly and having a step there.
I have also made a cardboard template of the core and the next step is to glue up the two 1/2" ply layers for the core, along with the center piece that will taper from 1/2" to 3/4" to equalize the transom thickness for the outdrive.
Thanks for the replies
Steve
