daveswaves
Ensign
- Joined
- Mar 22, 2002
- 901
Poof, this thread is gone.
op2:
opcorn:
I'm staying outta this one....
Yep, it's not a good choice:
In hindsight, the peanuts would have 'just barely' kept the big pressure treated box platform they were inside afloat.. Barely, and probably not at all after all that truck bedliner got sprayed all over everything :facepalm:
BTW: Some packing peanuts are now made of a water soluble styro, w/ a starch based substitute
Lots of peanut info.
BTW, part duex: often used in Hydroponic applications for their ability to absorb & hold water
Dave: I'd suggest you either restore the original post you redacted (it could be a resource for someone that follows us to iboats) or ask a MOD to delete this thread.
Your original question may have been met w/ less then favorable replies, but for good or bad, threads are a reference & resource. This thread now merely suggests what you asked, but who's to say someone else won't have a similar thought process or access to copious volumes of peanuts & little or no other use for them.
Clearly, a previous owner of my 1st SC Jet thought that they'd be a good substitute for flotation foam.
88Wellcraft asked the same question 6 years ago:
packing peanuts??
Lots of great info floating around iboats forum. I highly recommend the advanced search function from the resto homepage.....
And check out the 5 Flotation threads the iboat server lists at the bottom of your thread:
Similar Threads:
- Flotation
By jspriddy in forum Boat Restoration, Building, and Hull Repair
Replies: 4 Last Post: January 24th, 2012, 08:26 PM- Flotation - some better than none?
By aeviaanah in forum Boat Topics and Questions (not engine topics)
Replies: 36 Last Post: November 20th, 2011, 06:49 PM- Flotation
By MikeM8560 in forum Cobia Boats
Replies: 0 Last Post: April 27th, 2009, 09:49 PM- Flotation
By jay_merrill in forum Boat Restoration, Building, and Hull Repair
Replies: 4 Last Post: December 9th, 2008, 03:42 AM- Flotation
By SeaforLife in forum Boat Restoration, Building, and Hull Repair
Replies: 1 Last Post: July 5th, 2008, 11:58 AM
I didn't reply expecting an apology, but thank you.Thanks for the great post and the research. My apologies to the group. We have seen the ways peanuts don,t work,
