Flywheel eyebolt
foodfisher
Can't come up with the right search words. '85 Force 125. Need to lift it. Saw an eyebolt that screws on the flywheel somewhere on iboats. Directions please/thanks
Frank Acampora
Re: Flywheel eyebolt
Yeah, you can buy one, but you can also make a plate about 3/16 to 1/4 inch thick with three holes to match the three holes in the top of the flywheel. Three 1/4 X 20 bolts screw in.
Drill a hole in the center and screw in an eyebolt about 1/2 inch shank size you buy at Home-Depot.
Just as good, just as safe, and a lot cheaper.
foodfisher
Thanks, I think. $4 at home depot and it's hanging. Worked like a charm. Now I can see some real ugly that was out of sight/ out of mind. Some degreasing and it's off to RRitt. Thanks again
