Foam on Aluminum corrosion
Wildey
I dug all the foam out of the 1989 Lowe aluminum boat. It was poured right against the hull and inner partitions. Looks like the foam caused some corrosion, actually a few small pinhole size pits that go completely through the hull. Only a few, so I'll plug those. Ever seen foam do this ? Granted, it was partially wet. The foam in my Capri was poured in a polyethylene liner of sorts.Would a plastic lining like that help with the aluminum hull ? I just didn't expect corrosion where the foam was poured directly on the metal. Plan to re-pour this weekend.
Thanks
the wet foam held water against the aluminum. that is where the corrosion came from. the water with minerals in it, not the foam
Wildey
Very well, thanks !
That part will not get wet again ... not on my watch.
Cheers !
