Beachdaman
- Joined
- Mar 1, 2022
- 21
I dont understand that questionI finally enlarged the bow area. You would need to build a plywood triangular deck piece to cover the bow foam area. Is there LOADS of molded under ALL the cross seat benches ?
That foam is all gone… i was thinking of pouring foam under these areasBad English. Is all the foamed in place foam under every blue seat and walk thru ? If yes ? Then it should be enough to pass the USCG flotation test.
