Fogging Oil
boatgrunt
Most winterization instructions say to bring the engine to medium idle and spray fogging oil down the carburetor until it stalls. I did this, but it took me about 10 seconds and what seemed like half the can to stall the engine.
1. Is this normal?
2. If not, what did I do wrong?
3. Can you use too much fogging oil?
Boatin Bob
Re: Fogging Oil
just my personal experience but I have a couple of 460's that can be stubborn when it comes to stalling with the fogging oil. I have found that I need to use 2 cans at the same time with no straws attached to get sufficient spray down both barrels to do the job. I spray some some alternating until I see the white smoke coming out the exhaust and then give her both cans full blast, it works.
ziggy
Re: Fogging Oil
i just have one old IL6. but i had the same trouble. couldn't kill it with the foggin oil. i got me a new can of foggin oil and mentioned that i was havein that trouble to my dealer. his answer was. oh, we just fill up a cup with it (foggin oil) and slowly dump it in faster and faster till its foggin, then stalls. that worked....
Scaaty
Re: Fogging Oil
Mine won't quit either (350)...It starts to stumble though, which means theres some oil getting th the walls, and thats all that really counts
packerman
Re: Fogging Oil
I think this falls under the "for added protection" part of winterizing and when it's smoking and sputtering, that's always been good enough for me. I have skipped the fogging a few times and the engine is still going strong 20 years later with no work done on it.
