Just bought this boat (1987 Bayliner with 1986 Force 125 1251x6b), had motor lowered to clean up a few little things, lube starter, add low unit oil thru fill hole until runs out vent. It took about 12 or so ounces to fill. After filling, it sat for three days in the lowered position and I did not see any oil leaking. After putting water muffs on and starting engine, let idle a few mins, and at idle put it in fwd, then rev, no problem with that, then shut it down. Tipped up motor to get ready to tow to lake and when tipped up, I then noticed a small round hole, about 1/8" diameter in the front of the lower unit (about 3 inches up from the bottom) started weeping gear oil. I used to have a 1984 Force 125 long ago and do not remember this. The hole is perfectly round, like it is supposed to be there but I doubt it is supposed to weep oil. The leaking gear oil thru this hole did not happen when I filled it and it just sat. It only happened after I put water muffs on and ran motor, then tipped up to transport. I try to limit the water pressure but still have flow. I do not turn on water full blast. When I lower the motor it still weeps oil and water out that hole. After about 10 minutes with motor lowered, no more leaking oil but water is dripping out that hole. Water also drips out the small holes near the lower unit bolts to upper unit
Is this hole normally there?
Why no oil leak when filled but now oil leaks when tipped up after running motor?
One other clue, seller said he just replaced impeller (I do not know if he put it in the water to use it after the replacement)
