force 50 can i give it more power
lets go fishing
im like good old tim the tool man taylor my 88 force 50 runs good behind my lil 15ft boat but id like to go a little faster is there anything i can do like a prop change or whatever it does currently have hydrofoils on it should they stay or go and keep in mind i have no power trim thanks for your input:cool:
Frank Acampora
Re: force 50 can i give it more power
In some applications a hydrofoil can rob as much as 5 MPH. In others it does no harm. Since it is a bolt on, remove it and see what happens to speed and handling---you can always bolt it right back--five minutes.
If the engine is correctly propped for your hull, a prop change will only hurt you. If incorrectly propped, it will help. ---But there is not much choice for those small engines. Still, if you can get a couple of cheap props (on ebay or such) to experiment with--then what the hey!
If you bolt on a larger carburetor, you will get-----50 HP! See! the 50 is at the top of the displacement and HP for that series engine. There is not much bolt on hot-rodding you can do.
If you need to disassemble the engine to replace a piston, then it is worth modifying the ports. That will yeild some extra HP and probably a few MPH more. But if the engine is running well, it really is not worth the trouble to disassemble and do the port work. --Don't fix somthin' that 'aint broke!
