Re: Force 85hp No Spark! Top speed ?'s
I am having troubles with my 89 bayliner capri Chrysler 3 cyl L drive motor. I am not getting spark on the top or bottom cylinder. Middle cylinder seems fine, i can switch the wires coming out of the cd box from the middle to either top or bottom cylider coil and both plugs will spark(one at a time only). So my question is what do you think the problem is? Stator? Cd boxes? Anyone know how to test either the stator or cd box. Any and all help appreciated. Also has anyone else had this problem.
My second question is what kind of a top speed can i expect out of the boat? It is new to me and after i get it running i will find out but am curious now. Thanks again
Check all wiring including grounds, make sure there tight, check
any plug in connections on the wiring and make sure there crimped on good at the plugins.
You have ground straps on the L-Drive lower unit, may want to check those too just to make sure there grounded good!
Swap coil number two with coil number one, see if one fires, if it does the coil on one is bad, swap coil two with coil three, if three now fires the coil on three is bad.
It is possible that each CD module could have a bad half.
On the CD module for cylinder three, swap your wiring on the unused side of the CD module to clyinder three and see if you have fire on three now, if so half of the CD module was bad.
Take pictures of the wiring and have a manual with wiring diagrams handy while doing this!
Good Luck!
