It could still be stuck. The cable locked???----He checked and said it was in neutral in post #3
Franz Marine may have parts. www.franzmarine.comI’m having a hard time even finding parts for this thing. Any particular site? I’ve checked boats.net and Crowley marine with no luck.
I guess I don’t know what you’re referring to? Cable? Or pull cord?It could still be stuck. The cable locked?
Are you sure it is a 1991 ? according the website I'm looking on they made them 1984 - 1987 & 1996-1998Trying to change coils but don’t know how the wiring is suppose to be. It was not done when taking the flywheel off so I don’t know how it goes! Help!
That looks strikingly similar yes. And this might seem silly but how would I know if the shift interlock rod is stuck? It moves when I shift it between F N RIs this your starter?
I do believe so. My model # is 93F91A and serial is 1069Are you sure it is a 1991 ? according the website I'm looking on they made them 1984 - 1987 & 1996-1998
Maybe this helps?Trying to change coils but don’t know how the wiring is suppose to be. It was not done when taking the flywheel off so I don’t know how it goes! Help!
The adjustment could be off, causing it to lockThat looks strikingly similar yes. And this might seem silly but how would I know if the shift interlock rod is stuck? It moves when I shift it between F N R
