force gas line
19732009
can i go from 1/4 to 3/8 on gas line from tank to engine. i just go new line and bal at wall mart and that is the only size thay have pleas help want to get back on lake to day.
pnwboat
Re: force gas line
You can, but just make sure you use the worm gear type hose clamps that you tighten with a screw driver and check carefully for leaks. Sometimes the 3/8 fuel line has a tendency to leak if not really tightened down on a 1/4 fitting.
