Re: force tilt cylinder
There are two holes cut into the top cap. You need a spanner to unscrew it. You can--if you are careful-- use a small pipe wrench on the cap flange but it WILL mark it and dent it big time and it will look crappy. Most of the ones I have opened have been very tight and corroded some. Very difficult to remove even though it is a relatively straightforward job.
