Re: ford ranger and trailor
Semi weigh more then the load they carry?
What about Suburbans/1 ton pickups hauling 12,000 pounds? The tow vehicle does not need to weigh more then the trailer weight. Thats a bunch of hoey. Don't exceed the manufacutres recommendations.
Trailer brakes are always a good idea, however not having them set properly is just as bad as not having them.
4wdr or a rear locker are always preferrred to an open rear diff on a 2wdr.
I also highly recommned Truck Tires if you plan on towing, they handle the load much better then passenger tires. Truck tires have stiffer sidewalls and reduce the likelyhood of wobble, especilly in a cross wind. I am partial to the BFg All-Terrains. Great tire.
If you have an auto tranny, install an auxilary tranny cooler, your tranny will live longer. If you find your tranny hunting for a gear, slow down, or downshift. All that hunting for a gear leads to excessive heat build up, and heat is the number one enemy of the tranny. The heat wont show up in your rad temp gauge, it is tranny heat and unless you have a tranny temp gauge you wont know its going up.
