Re: front motor mount
Ayuh,... I'm thinking that whoever mounted that motor the 1st time, did so with the mount somewhat crooked...
With the single adjusting bolt centered, it can be pivoted, depending where the lagbolt hole is drilled...
If you've got an alignment bar, you could move the mount, fill the holes in the wood, reposition the mount, redrill the holes,+ have the space needed to change belts...
