Hi, finaly i did all the test on my mercruiser 4.3l and got cylinder 1 and 5 with 120LBS cylinder 3 105lbs, everything looks good until now but got to the starboard, cylinders 2 and 4 30lbs, cylinder 6 0lbs. i did filled with wd40, and seafoam after to loose any ring that could be stocked with gum buildup but after i removed the valves cover i noticed this, the push rods seems ok not bent or anything, but the admission valve on all 3 cylinder (2,4,6) are frozen open (down) what is the best way to try without go with complete unassembly and rebuilding everything. is there any way to move them a little up and down to make them move?
